Date/Time: Tue, 26 Nov 2024 22:41:29 +0000
could the chart be set some space shift to left?
View Count: 1089
[2014-06-25 06:39:23] |
User83601 - Posts: 8 |
Could the chart be set some space shift to left? Just like the attached file Date Time Of Last Edit: 2014-06-25 09:47:00
[2014-06-25 16:51:01] |
Yes can this can be done and is documented here: http://www.sierrachart.com/index.php?l=doc/doc_WorkingWithCharts.html#ScrollingTheChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-26 00:01:46] |
Thank you. Sierra Chart is so great. |
