Date/Time: Thu, 28 Nov 2024 09:43:13 +0000
Alert and Arrow code per conditions
View Count: 352
[2023-05-06 16:24:16] |
joed369 - Posts: 1 |
Hello, i have been working on a system in sierra for trading, i used to use TD and i am decent at coding thinkscript but i have no idea how to code on sierra. i would like to find out if i can get an alert system with the following variables from someone. I use volume bars but i overlay a 1 min chart 20 Exponential moving average on there, also i use volume ratio, up down trade ratio and chaiken as indicators, along with VWAPS. if an alert to be able to mark if above the Overlay 20 exponential, plus Daily VWAP, and Real time hours VWAP and both ratios positive and chaiken also positive to have an alert and arrow to signal when all the combinations are in agreement, and or turn on or off any one of the variables depending on the time, or bar frame. Thank you |
[2023-05-08 19:38:13] |
Sierra_Chart Engineering - Posts: 17201 |
You can do this in Sierra Chart. A simple way to start with this would be to use the Spreadsheet System/Alert Study: Spreadsheet Systems, Alerts and Automated Trading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
