Date/Time: Thu, 28 Nov 2024 09:51:31 +0000
volume at price threshold alert v2 help
View Count: 516
[2023-05-06 15:28:41] |
User424141 - Posts: 6 |
Hi Is it possible to set the "volume at price threshold alert v2" like this? Check the attachment. So when the price first touches (even if it's just a little touch, so the price is not fully breaks the imbalance) a stacked imbalance, from that point it stops to mark it furthermore. Currently SC is just "bites off" a piece from the stacked imbalance, and I dont want that. Touch-> stop marking furthermore the entire imbalance, I want this. Let me know if this is possible, but I dont think so...? Date Time Of Last Edit: 2023-05-06 15:29:48
example2.jpg / V - Attached On 2023-05-06 15:25:46 UTC - Size: 381.53 KB - 156 views example1.jpg / V - Attached On 2023-05-06 15:26:17 UTC - Size: 213.82 KB - 119 views example3.jpg / V - Attached On 2023-05-06 15:26:22 UTC - Size: 323.76 KB - 109 views |
[2023-05-08 19:30:09] |
Sierra_Chart Engineering - Posts: 17201 |
You can modify that particular study to meet your requirements: How to Build an Advanced Custom Study from Source Code The source code is provided. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-05-08 19:31:19
