Date/Time: Thu, 28 Nov 2024 09:43:13 +0000
Transparent Label Background (ACSIL) Subgraph member?
View Count: 345
[2023-05-06 13:53:24]
User92573 - Posts: 530
Dear Support
I already use the option for a Traparent Label Background when using tools i.e.,
Tool.TransparentLabelBackground
sc.AddAndManageSingleTextUserDrawnDrawingForStudy(sc, 0, HorizontalPosition, VerticalPosition, Subgraph_Clock, "TransparentLabelBackground", DateString, DrawAboveMainPriceGraph, 0, UseBoldFont);
... and Study >> settings >> Subgraphs provides an option to "Use Transparent Label Background."
However, I cannot locate the ACSIL Subgraph member to format a "Subgraph Label Background" in the same way.
If this exists and I've simply missed it, please can you direct me to "Use Transparent Label Background" for a Subgraph.
Many thanks
[2023-05-06 14:14:15]
User907968 - Posts: 823
Try using UseTransparentLabelBackground, it is a member of the subgraph class that doesn't seem to be documented.
[2023-05-06 16:50:17]
User907968
Many thanks. I thought I'd gone through the header but obviously missed it as failed to include "use".
Great help, thank you.
