Date/Time: Thu, 28 Nov 2024 09:42:29 +0000
Unable to connect to Teton data all the sudden
View Count: 268
[2023-05-06 13:21:41] |
User525965 - Posts: 153 |
When I opened Sierra data I kept getting this error message. Have never seen this before. Please assist My data connection to Rithmic is working fine, its just Teton that is not working. Attached is screenshot of the error messages |
Screenshot_2.png / V - Attached On 2023-05-06 13:20:50 UTC - Size: 145.51 KB - 82 views Attachment Deleted. |
[2023-05-06 14:47:32] |
Sierra_Chart Engineering - Posts: 17201 |
Teton order routing was down for maintenance earlier today. You will be able to connect now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-05-06 14:47:39
