Date/Time: Thu, 28 Nov 2024 11:00:20 +0000
Visible Bars Ticks Per Volume Bar minimum
View Count: 277
[2023-05-05 13:30:18] |
$tack - Posts: 87 |
For some of my charts the minimum Ticks Per Volume Bar will not go below 5. Is there a reason for this? Thanks |
[2023-05-05 14:48:08] |
Sierra_Chart Engineering - Posts: 17201 |
The reason is explained here: Volume By Price Study: Ticks Per Volume Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
