Date/Time: Thu, 28 Nov 2024 09:47:16 +0000
Study Angle
View Count: 623
[2023-05-05 10:58:52]
User411320 - Posts: 289
In input 2 (length), does 1 equal 2 bars? based off "A 45 degree line is a line with a slope of 1. The formula for slope is Rise divided by Run. A Line drawn across 2 bars is considered a span of 1 bar."
[2023-05-05 16:51:42]
John - SC Support - Posts: 36350
The study subtracts the Length from the calculation bar to determine the bar from which the angle is determined. In other words, a Length of 1 does use 2 bars (the current bar and the bar just before it).
[2023-05-07 18:04:38]
just to confirm would a length of 2 be 3 bars or 4 bars?
[2023-05-08 11:43:30]
Sierra_Chart Engineering - Posts: 17201
The Length Input specifies the number of bars back to reference. Therefore, with a Length of 1 the angle will be calculated from the current bar being processed, and the bar before. A Length of 2 would mean that the angle will be calculated from the current bar being processed and 2 bars before.
Date Time Of Last Edit: 2023-05-08 11:43:47
