Date/Time: Thu, 28 Nov 2024 10:48:24 +0000
Teton and cqg
View Count: 394
[2023-05-05 08:35:14] |
User68acg - Posts: 15 |
Hi. I have an amp live ac and have been using cqg data with SSC Denali. I am told I can swap now to Teton How does one do this? Do I modify my package on the amp site and ask for Sierra Teton feed and THEN go to SC and change Selected Service to Teton and change the Clearing firm too? - to what? All a bit confusing. Thanks Andy |
[2023-05-05 12:00:31] |
Sierra_Chart Engineering - Posts: 17201 |
To use Teton order routing just follow the instructions here: Sierra Chart Teton Futures Order Routing: Setup Instructions There are no Service Package changes needed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-05 12:41:30] |
ondafringe - Posts: 286 |
But first: 1. Make sure you have no open positions 2. Login to your funded AMP account 3. Select Trade Desk from left panel 4. Under that, select Live Trading Setup Request 5. At top, click New Live Trading Setup Request Fill out the form and, at the bottom of the form, select Sierra (Teton), and submit the form. Note: As another poster mentioned, if you had any trade executions for that day, wait until after 5 PM Central Time to submit your request. AMP may or may not send you an email when your new setup is complete, but it should take less than 24 hours. |
