Date/Time: Thu, 28 Nov 2024 10:36:29 +0000
Steps required to receive realtime prices from CME, and see large history inside Sierra
View Count: 338
[2023-05-04 20:38:13]
User424141 - Posts: 6
Hi
Please guide me for this, tell me what I need exactly. I know you have very detailed guides, so if you just write a few word step by step, I can do it myself then. Cheapest and easiest way.
I want to see realtime prices inside Sierra for CME Euro futures.
I don't want to trade from Sierra, just analyzing CME Euro futures on Sierra charts.
I need large history data, for number bars with detailed bid*ask. More than a year.
I dont need market depth data.
It's clear I have to purchase Sierra.
But it's not clear who gets the CME exchange fee. (SC or the broker)
It's also not clear if I will have realtime prices from a service, how I will get the years of bid*ask data for my needs from Sierra ( Sierra mentioned they have very good history data, and it's true, I see it in the trial Sierra, thats what I want along with realtime quotes as well because trial is delayed data).
I read SC guides since days, but it's still foggy at the moment.
Please light me up, thanks
Date Time Of Last Edit: 2023-05-04 20:40:00
[2023-05-04 21:00:19]
John - SC Support - Posts: 36350
To begin with, you will definitely need to use our data, as you will not be able to get the historical data from anyone else.
Next, you need to be aware that in order to get data from the CME Group at the, much lower priced, Non-Professional exchange fees, you need to have a live, funded, futures trading account. This is a CME Group requirement. Refer to the following for more information:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
If you do not have an account that you can use to meet the above non-professional requirement, then we recommend the solution given at the following link:
Easy Solution to CME Funded Trading Account Requirement
Let us know how you are going to handle the above and if you are going the non-professional route, what broker/trading service you will be using so we can point you to the proper instructions.
[2023-05-04 21:26:01]
Thanks.
Then it seems I need an account somewhere first.
It will be done at Stage 5 or Edge Clear most likely.
Lets say I do that, then whats next?
[2023-05-05 16:32:17]
Once you get you account setup with either Stage 5 or Edge Clear, then you will need to setup the Teton Order Routing Service to connect your Sierra Chart to that account. To do this, you will follow the instructions at the following link:
Sierra Chart Teton Futures Order Routing: Setup Instructions
Note in the above instructions is references setting up the Denali Exchange Data Feed. You can it then, or after you finish the setup, either one is fine.
Once you have the Teton connection setup and the Denali Data Feed setup then you are done.
