Date/Time: Thu, 28 Nov 2024 11:05:16 +0000
Import Subgraph
View Count: 325
[2023-05-04 19:47:55]
User585993 - Posts: 83
How can I import a subgraph values in another chart? I need to add the TPO VA & POC as seen in the attched image.
[2023-05-04 20:49:27]
John - SC Support - Posts: 36350
There is no attachment, but if you are trying to get the data from a TPO chart, this will not work. The Value Area and POC are not actually stored in the subgraphs, the subgraphs are just to set the colors and widths of those lines.
The best thing to do is to use the "TPO Value Area Lines" study on the other chart. Just make sure it is set the same way as the TPO's you want to reference from. Refer to the following:
Also, if you use the Volume Value Area and POC, then there is the "Volume Value Area Lines" study that is based on the volume information. Refer to the following:
