Date/Time: Thu, 28 Nov 2024 10:46:10 +0000
USCT Feed Issue
View Count: 309
[2023-05-04 19:22:13] |
pampolpops - Posts: 12 |
I've subscribed for the USCT feed and when I use it sometimes it will stop updating. I am not sure what the issue is as the NQTV ticker continuously updates but USCT just suddenly stops. There are no odd error messages in the message log regariding the USCT ticker. |
[2023-05-04 19:41:49] |
Sierra_Chart Engineering - Posts: 17201 |
Based upon what we see you are not running an up to date version of Sierra Chart. Update following these instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-05-04 19:41:57
