Date/Time: Thu, 28 Nov 2024 10:53:57 +0000
graphs of instruments
View Count: 294
[2023-05-04 18:49:59] |
User440160 - Posts: 76 |
Subject updated from 'link broker with sierra charts' to 'graphs of instruments' -------------------------------------------------------------------------------- Hi Could you please give me instructions on how to load graphs of an instrument next to my Depth of Market Graph? I have attached an example below. I am interested only on how to make the graph appear I would appreciate a quick reply best marios |
Attachment Deleted. |
[2023-05-04 20:40:07] |
It's just a matter of "Un-Maximizing" your charts so you can put them wherever you want within the graphics area. Refer to the following for some of the window layout options which you can start with, and then adjust from there: Window, CB and CW Menus: Cascade (Window) You can also detach windows and then lay them out as you want on your desktop. Refer to the following: Detaching and Attaching Chart Windows For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
