Date/Time: Thu, 28 Nov 2024 10:59:48 +0000
Mark/Highlight a price on price ladder tool
View Count: 683
[2023-05-04 17:14:34] |
User392433 - Posts: 42 |
Hi, I would like to be able mark/highlight and unmark/unhighlight a price on the price ladder/dom. Success Criteria: Should be able to click a price on the price ladder and then have that price box to be filled with a set color, where price itself can still be visible. Ideally, it looks something like how the bid/ask boxes look right now, but at the one price marked. Should be able to remove mark highlight by clicking. Should be able to choose color for highlight. Bonus: Be able to mark on price ladder and then automatically copy highlight to another chart and mark on chart and copy copy chart highlight to price ladder. Currently, I am doing something similar with the drawing tool horizontal line, but the drawings only show up to the left of the dom, rather than on the price itself. It is out of the way (harder to notice/see), and completely blocked if you have any orders on as it is in the same area that working orders are shown. Thanks |
[2023-05-04 20:25:37] |
You would want to use the Subgraph Value Label for this. Depending on what you want, you can use the Horizontal Lines study to define the line positions and then turn on the Value Label for the lines. The value label can be put to the left side of the graphics area, the right side, in the Price Ladder, or in their own column in the DOM (Label Column). Refer to the information at the following link for the Value Label: Chart Studies: Subgraphs Tab >> Name and Value Labels Refer to the information at the following link the Horizontal Lines study: Horizontal Lines For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-04 20:32:38] |
The problem is that you can't click a price to set it or unset it. You have to create the new study
[2023-05-04 20:53:53] |
Then we do not have exactly what you are wanting.
[2023-05-04 22:57:31] |
Oh I set feature request in the title but it seems to not have been added to title. Can I request this as a feature?
[2023-05-05 16:34:02] |
Yes, we have tagged it as a feature request. Pretty much anything that is requested that we do not have is considered a feature request by default. Keep in mind that we can not say when we will get to any particular request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
