Date/Time: Thu, 28 Nov 2024 11:00:29 +0000
I am a Sierra Chart and AMP account holder but got the following message after updating
View Count: 300
[2023-05-04 17:03:07] |
User663078 - Posts: 13 |
I updated to 2170 Connection error message from service SC Futures Order Routing/Data Connection error Trade account not assigned |
[2023-05-04 17:05:40] |
Sierra_Chart Engineering - Posts: 17201 |
This is a very old version from years ago which has no support for Teton order routing. You need to update to the current version following these instructions: Software Download: Fast Update And then follow the instructions here: Sierra Chart Teton Futures Order Routing: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-05-04 17:14:38
