Date/Time: Tue, 26 Nov 2024 22:33:37 +0000
Compact Tool Values window disappears on v1151 upgrade
View Count: 931
[2014-06-24 22:41:38] |
bekitz - Posts: 26 |
With "CTV" button enabled on toolbar, this window is no longer visible using the crosshair cursor. It looks like part of the outline (one side) of the box is visible but that's it. Upgraded from v1137.
[2014-06-25 01:22:05] |
We do see this problem. And we will be resolving it.
