Date/Time: Thu, 28 Nov 2024 11:02:01 +0000
Position line disappears after order is filled
View Count: 447
[2023-05-03 15:25:08] |
traderz - Posts: 4 |
Hello, The order association lines seem fine. However, once the order is filled, the position line isn't connected to the target or stop, and it disappears. Please see the screenshots. I have the following settings: "Chart settings" ---> "trading" ---> "display order association lines" --> to "yes" "Global settings" ---> "Chart trade setting" ---> "order fills" --> "display entry/exit connecting lines" to "yes" If I have multiple orders and order fills. It should connect the position with associated target/stop respectively. Thanks, |
SierraChart_64_RyPpPsKzz6.png / V - Attached On 2023-05-03 15:24:08 UTC - Size: 13.85 KB - 80 views SierraChart_64_zr5WRmxNei.png / V - Attached On 2023-05-03 15:24:14 UTC - Size: 12.45 KB - 75 views Attachment Deleted. |
[2023-05-04 11:10:25] |
Sierra_Chart Engineering - Posts: 17201 |
What you are looking for is not supported. There is not a connecting line from Attached Orders to the Position line itself.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-05-04 11:10:34
