Date/Time: Thu, 28 Nov 2024 10:38:50 +0000
Trade DOM Horizontal Spacing controls
View Count: 355
[2023-05-03 14:43:26] |
Jimmyz83 - Posts: 52 |
See attached pic, I have been looking for a couple days and can not find how to change the horizontal spacing (gap between the top line and bottom line) allowing more horizontal lines and data to be on the same DOM page. Can you help, thanks.
Screenshot 2023-05-03 093340.jpg / V - Attached On 2023-05-03 14:38:35 UTC - Size: 64.82 KB - 103 views Attachment Deleted. |
[2023-05-03 16:21:55] |
It looks like you have a column displayed in that area. Go to Trade >> Customize Chart/Trade DOM Columns and look for a column listed below the "Price" column. If there is one there, move it up in the list (so it moves to the left) or remove it. Refer to the following: Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-03 16:31:43] |
I dont want to remove the column, I am looking to take the horizontal line spacing and make it smaller. the circle is just to point out the space between the horizontal lines. I want to shrink that space. if I go in and reduce the text it does not shrink the spacing of the line. Can you help with where that setting is? tks
[2023-05-03 16:50:18] |
Ahhh, ok, we see what you are wanting to do. In order to change that spacing, you need to adjust the "Range" of the price data. You would need to extend the range (shrink the spacing) to do this. Refer to the following: Chart Scale and Scale Adjusting: Interactive Scale Range - Expand/Compress Scale For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
