Date/Time: Thu, 28 Nov 2024 08:48:12 +0000
Bitfinex depth
View Count: 295
[2023-05-02 20:04:05] |
Cyberdogk9 - Posts: 27 |
Hi, Bitfinex provides full market depth, but when I open market depth windows for BTCUSD i see for example right now only 177 available levels on bid and 34 levels on ask. Can you please explain what is wrong here? And is it possible to provide maximum Sierrachart limit of available depth levels of 1400? |
[2023-05-03 22:26:28] |
Sierra_Chart Engineering - Posts: 17200 |
It has been a long time since we have done any work with this Bitfinex data feed, but from what we remember, the particular interface we use, it does have limited depth. You definitely will not see the full depth.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-05-03 22:26:33
[2023-05-03 22:38:47] |
It would be ok not to get Bitfinex full depth, I get it it's huge. But the depth that right now is available through Sierrachart doesn't make sense. Look at screenshot it jumps and for some reason it shows 0 price level... And at some point i can see almost only bids or only asks. It's broken. |
bitfinex depth.png / V - Attached On 2023-05-03 22:36:33 UTC - Size: 94.43 KB - 73 views |
[2023-05-16 16:08:15] |
There is limited depth through the websocket connection that Sierra Chart uses to Bitfinex. What you see is coming from Bitfinex. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
