Date/Time: Thu, 28 Nov 2024 10:46:38 +0000
how to assign a new live funded trade account?
View Count: 462
[2023-05-02 16:32:20]
User85195 - Posts: 60
I've a live funded account with AMP and I've already assigned it as my live trading account so that I can access real time trading data from the exchanges.
however I'm having problem with AMP and I'm now unable to log into my AMP live trading account.
as a result, I've been receiving delayed date feed for the last few days.
I have another live funded trading account with IB, and I've logged into it from sierrachart, but my data feed is still delayed.
what is the reason for this delay? do I need to assign IB as my live trading account? if so, please give me a link to do so. I've searched but couldn't find it anywhere in my account page.
[2023-05-02 17:30:34]
John - SC Support - Posts: 36350
Everything on your account looks good, so you should be getting real-time data for the CME Group.
Make sure that you have the correct symbols since you switched to IB. Open your chartbooks and select "Edit >> Translate Symbols to Current Service".
If you are still having an issue after this, then we would need to see your Message Log by following these instructions:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Tell us about *one* symbol only.
[2023-05-03 13:44:12]
the symbol is: MNQM3.cme
I have both SC and Rtraderpro open, the data feed in SC is a few minutes late for some reason. but the timestamp is the same in both platforms.
Software version: 2497 64-bit | 2023-05-03 22:39:56.074
Primary Thread ID: 14296 | 2023-05-03 22:39:56.074
Usage end date: 2023-09-05 | 2023-05-03 22:39:56.074
Enabled for: Sierra Chart Historical Data Service. | 2023-05-03 22:39:56.074
Enabled for: Denali Real-Time Exchange Data Feed. | 2023-05-03 22:39:56.074
Enabled for: Delayed Denali Exchange Data Feed. | 2023-05-03 22:39:56.074
Enabled for exchange2: CME (Trading Account Required) | 2023-05-03 22:39:56.074
Enabled for exchange2: CBOT (Trading Account Required) | 2023-05-03 22:39:56.074
Enabled for exchange2: COMEX (Trading Account Required) | 2023-05-03 22:39:56.074
Enabled for exchange2: NYMEX (Trading Account Required) | 2023-05-03 22:39:56.074
Enabled for exchange2: fairx_exchange.data | 2023-05-03 22:39:56.074
Allow Support for Sierra Chart Data Feeds is enabled. | 2023-05-03 22:39:56.074
Current selected Data/Trading service: Rithmic Direct - DTC | 2023-05-03 22:39:56.074
Custom symbol settings values: enabled | 2023-05-03 22:39:56.074
Chart Update Interval: 100 | 2023-05-03 22:39:56.074
Intraday Data Storage Time Unit: 0 | 2023-05-03 22:39:56.074
Time Zone: +09:00:00 (JST+09) | 2023-05-03 22:39:56.074
2023-05-03 13:39:56 Local computer time in UTC | 2023-05-03 22:39:56.074
2023-05-03 22:39:56 Local computer time in SC Time Zone | 2023-05-03 22:39:56.074
2023-05-03 09:53:10 Server time in UTC | 2023-05-03 22:39:56.074
Local computer UTC time and Server UTC time difference: 4 seconds. | 2023-05-03 22:39:56.074
Program path: D:\Trading\APEX\ | 2023-05-03 22:39:56.074
Data Files path: D:\Trading\APEX\Data\ | 2023-05-03 22:39:56.074
OS Version Number: 10.0 | 2023-05-03 22:39:56.075
Locale Setting: C | 2023-05-03 22:39:56.075
DLLs: DelayedOrNot_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2023-05-03 22:39:56.075
Allowed protected custom studies: | 2023-05-03 22:39:56.075
Crash reporter started: true | 2023-05-03 22:39:56.075
File >> Disconnect selected. | 2023-05-03 22:39:58.511
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2023-05-03 22:39:58.512
DTC Client socket (1) | CloseSocket call. | 2023-05-03 22:39:58.512
DTC Client socket (1) | Max send buffers used during socket life: 4 | 2023-05-03 22:39:58.512
DTC Client socket (1) | Max send buffer size during socket life: 637 | 2023-05-03 22:39:58.512
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-05-03 22:39:58.512
Denali Data Feed | Waiting for socket receive thread to end | 2023-05-03 22:39:58.512
DTC Client socket (3) | CloseSocket call. | 2023-05-03 22:39:58.513
Denali Data Feed | Disconnected from the server. | 2023-05-03 22:39:58.513
Rithmic Direct - DTC | Disconnected. | 2023-05-03 22:39:58.513
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2023-05-03 22:39:58.513
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-05-03 22:39:58.772
DTC Client socket (1) | Closed. | 2023-05-03 22:39:58.772
Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated | 2023-05-03 22:40:01.418
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 | 2023-05-03 22:40:01.418
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-05-03 22:40:01.421
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-05-03 22:40:01.421
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2023-05-03 22:40:01.421
Rithmic Direct - DTC | Network connection to server complete. | 2023-05-03 22:40:01.673
Rithmic Direct - DTC | Starting socket receive thread. | 2023-05-03 22:40:01.673
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-05-03 22:40:01.673
Rithmic Direct - DTC | Sending logon request message. | 2023-05-03 22:40:01.673
Rithmic Direct - DTC | Received logon response. | 2023-05-03 22:40:03.205
Rithmic Direct - DTC | Server Name: . | 2023-05-03 22:40:03.205
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2023-05-03 22:40:03.205
Rithmic Direct - DTC | Successfully connected. | 2023-05-03 22:40:03.205
Rithmic Direct - DTC | Trading is supported. | 2023-05-03 22:40:03.205
Rithmic Direct - DTC | Order cancel and replace is supported. | 2023-05-03 22:40:03.205
Rithmic Direct - DTC | OCO Orders supported. | 2023-05-03 22:40:03.205
Rithmic Direct - DTC | Symbol and Exchange Delimiter: . | 2023-05-03 22:40:03.205
Rithmic Direct - DTC | Connected to server complete. | 2023-05-03 22:40:03.205
Triggering next historical data download in queue. | 2023-05-03 22:40:03.206
No download requests in the queue to start downloads for. | 2023-05-03 22:40:03.208
Mapping MNQM3.CME to MNQM23. Service code: cme | 2023-05-03 22:40:03.248
Using symbol data fast lookup vector | 2023-05-03 22:40:03.248
Denali Data Feed | Starting real-time market data updates for: MNQM3.CME (MNQM23). ID: 1 Service code: cme | 2023-05-03 22:40:03.248
Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 10048 | 2023-05-03 22:40:03.248
Denali Data Feed | Requesting security definition data for: MNQM3.CME (MNQM23). ID: 1 | 2023-05-03 22:40:03.248
DTC Client socket (2) | Creating socket. | 2023-05-03 22:40:03.252
DTC Client socket (2) | New receive buffer size: 5242880 | 2023-05-03 22:40:03.252
DTC Client socket (2) | Connecting to IP: 142.215.18.147. | 2023-05-03 22:40:03.252
Added historical Intraday data request for MNQM3.CME to the queue. | 2023-05-03 22:40:03.255
Intraday data recording state for symbol MNQM3.CME is set to download 'Pending'. | 2023-05-03 22:40:03.255
Triggering next historical data download in queue. | 2023-05-03 22:40:03.255
Delaying start of download for MNQM3.CME. | 2023-05-03 22:40:03.266
Denali Data Feed | Network connection to server complete. | 2023-05-03 22:40:06.483
Denali Data Feed | Starting socket receive thread. | 2023-05-03 22:40:06.483
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-05-03 22:40:06.483
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-05-03 22:40:06.749
Denali Data Feed | Sending logon request message. | 2023-05-03 22:40:06.749
Requesting market depth updates for: MNQM3.CME if supported. | 2023-05-03 22:40:08.233
Separate subscription for market depth updates not supported. MNQM3.CME | 2023-05-03 22:40:08.233
Denali Data Feed | Received logon response. | 2023-05-03 22:40:10.124
Denali Data Feed | Server Name: SC Realtime Server. | 2023-05-03 22:40:10.124
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-05-03 22:40:10.124
Denali Data Feed | Successfully connected. | 2023-05-03 22:40:10.124
Denali Data Feed | Trading is not supported. | 2023-05-03 22:40:10.124
Denali Data Feed | Restarting real-time data updates for symbol: MNQM3.CME -> MNQM23. Market Depth data restarted. | 2023-05-03 22:40:10.124
Denali Data Feed | Received security definition for symbol MNQM3.CME | 2023-05-03 22:40:10.436
Denali Data Feed | Market Depth data has been rejected for symbol: MNQM3.CME. Not authorized for market depth. | 2023-05-03 22:40:10.436
HD Request # 8 | Downloading Intraday chart data for MNQM3.CME to the file MNQM3.CME.scid. Service: cme | 2023-05-03 22:40:15.885
HD Request # 8 | Download start date-time: 2023-05-03 22:39:57.000000. File last date-time: 2023-05-03 22:39:57.349000 | 2023-05-03 22:40:15.886
HD Request # 8 | Using server: ds23.sierracharts.com port 10149 | 2023-05-03 22:40:15.886
Socket (4) | Creating socket. | 2023-05-03 22:40:15.886
Socket (4) | New receive buffer size: 5242880 | 2023-05-03 22:40:15.886
Socket (4) | Connecting to IP: 142.215.17.190. | 2023-05-03 22:40:15.886
HD Request # 8 | Setting DTC encoding to Binary VLS | 2023-05-03 22:40:16.348
HD Request # 8 | Sending historical data logon request message. | 2023-05-03 22:40:16.348
HD Request # 8 | Requesting Intraday data. Start date-time: 2023-05-03 22:39:57. Record interval: 0. Symbol: MNQM23 | 2023-05-03 22:40:17.728
HD Request # 8 | Decompressing data. | 2023-05-03 22:40:17.957
HD Request # 8 | Receiving Intraday data for MNQM3.CME starting at 2023-05-03 22:39:57.003000 | 2023-05-03 22:40:18.691
Socket (4) | CloseSocket call. | 2023-05-03 22:40:18.885
Socket (4) | Shutdown started. Waiting for graceful close. | 2023-05-03 22:40:18.885
Historical data download thread signaled to stop. | 2023-05-03 22:40:18.885
HD Request # 8 | Timestamp of first Intraday data file record written: 2023-05-03 22:39:57.741000. | 2023-05-03 22:40:18.885
HD Request # 8 | Received 954 Intraday data records from 2023-05-03 22:39:57.003000 to 2023-05-03 22:40:16.766004 (19.8 seconds. Delay: 2.1 seconds) and wrote 945 records for MNQM3.CME | 2023-05-03 22:40:18.885
HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2023-05-03 13:40:16.766004 | 2023-05-03 22:40:18.890
Added 14 Time and Sales records to Intraday data file for MNQM3.CME after download. | 2023-05-03 22:40:18.890
HD Request # 8 | Completion time: 3s. | 2023-05-03 22:40:18.890
HD Request # 8 | Intraday data download complete for MNQM3.CME. Unique request ID: 8 | 2023-05-03 22:40:18.890
Removing historical data download ID 8. | 2023-05-03 22:40:18.890
Real-time Intraday chart data file updates started for MNQM3.CME | 2023-05-03 22:40:18.890
Intraday chart data file opened for MNQM3.CME | 2023-05-03 22:40:18.890
HD Request # 8 | Enabling Intraday chart updating for symbol. | 2023-05-03 22:40:18.890
Triggering next historical data download in queue. | 2023-05-03 22:40:18.890
No download requests in the queue to start downloads for. | 2023-05-03 22:40:18.890
Socket (4) | Socket gracefully closed by remote side. | 2023-05-03 22:40:19.114
Socket (4) | Closed. | 2023-05-03 22:40:19.114
Opened cached Intraday file: D:\Trading\APEX\Data\MNQM3.CME.scid. Thread ID: 12748 | 2023-05-03 22:40:20.574
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (4) | Creating socket. Using TLS 1.2. | 2023-05-03 22:40:21.417
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (4) | New receive buffer size: 32768 | 2023-05-03 22:40:21.417
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (4) | Connecting to IP: 38.79.0.89. | 2023-05-03 22:40:21.417
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (4) | New receive buffer size: 65536 | 2023-05-03 22:40:23.659
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (4) | Socket gracefully closed by remote side. | 2023-05-03 22:40:24.508
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (4) | CloseSocket call. | 2023-05-03 22:40:24.508
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-05-03 22:40:24.509
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (4) | Closed. | 2023-05-03 22:40:24.509
[2023-05-03 16:13:37]
Everything in your log is fine.
So it sounds like you are getting the real-time data now, but it is behind by "a couple of minutes"?
What exactly is occurring? Do you have any indication of a delay in the data on your Sierra Chart system?
[2023-05-04 07:18:29]
first time I noticed the delay was on Monday, my stoploss was triggered a couple of times when price clearly didn't touch it on the chart. so I opened a chart in RTraderPro for the same symbol in the same timeframe, and to my shock it was showing a different price and almost one full bar ahead of the chart in SC, and yet the timestamp in both charts were the same. this lasted until yesterday, when I noticed a switch. RTraderPro became the one with the delayed datafeed, a couple of minutes behind SC.
I have no idea what is going on. both platforms were working fine before Monday. I didn't change any configurations in both platforms for as long as I could remember. a few days prior to the problem occurring, I did receive notifications asking me to connect to my live funded trading account in order to keep receiving real time data feed. I couldn't connect to AMP so I connected to IB instead. and the notifications disappeared so I thought it was done. but I started getting delayed datafeed not long afterwards.
[2023-05-04 09:44:02]
Sierra_Chart Engineering - Posts: 17201
Refer to:
Prices / Data Falling Behind
Check the Data Delay field and see how much of a delay there is:
Working With Charts: Region Data Line / Chart Header
Set "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds" to Yes. If it was not yes, reconnect to the data feed with File >> Reconnect.
Date Time Of Last Edit: 2023-05-04 09:45:27
