Date/Time: Thu, 28 Nov 2024 12:46:22 +0000
Attached orders not working
View Count: 405
[2023-05-02 14:59:58] |
User585993 - Posts: 83 |
Unable to use the attached orders, no target or stop loss even though I have checked (use attached order) on the trade window and I have the target and stop loss, could you please advise?
Attachment Deleted. IMG_9494.jpg / V - Attached On 2023-05-02 14:59:28 UTC - Size: 2.21 MB - 109 views IMG_9495.jpg / V - Attached On 2023-05-02 14:59:39 UTC - Size: 2.25 MB - 95 views |
[2023-05-02 17:20:19] |
You have your Target set as a "Market if Touched". Many of the exchanges do not allow this type of order, so we are guessing that this is causing a rejection of the orders. To know for sure, check your "Trade >> Trade Service Log" after you try to place the order and see what it states in there. You should just use a Limit order for the target. If you need to use a Market if Touched, then you would have to use a Client side version, so the attached orders will not be on the exchange, just on your local system until it is sent to the exchange as a Market order. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
