Date/Time: Thu, 28 Nov 2024 12:51:33 +0000
Volume profile not loading correctly on DOM
View Count: 405
[2023-05-02 14:40:27] |
User346364 - Posts: 14 |
I have the Volume at Price study on my DOM. It seems to be loading multiple prices at the same time, as well as showing total volume the same across several prices. For example, market is trading 4219 - 4130 and the volumes are being added a full point below where the market is trading. See attached screenshots. Is this a bug or a setting? Date Time Of Last Edit: 2023-05-02 14:41:42
Screenshot 2023-05-02 153826.png / V - Attached On 2023-05-02 14:40:07 UTC - Size: 128.81 KB - 92 views Screenshot 2023-05-02 153851.png / V - Attached On 2023-05-02 14:40:12 UTC - Size: 161.52 KB - 97 views |
[2023-05-02 14:41:01] |
Sierra_Chart Engineering - Posts: 17201 |
Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-02 14:44:28] |
Ok thanks - presuming because it was set to 1 minute it would load the volumes to the DOM based on that?
