Date/Time: Tue, 26 Nov 2024 22:34:51 +0000
Sierra Chart 1150 : problems update positions CBOT
View Count: 1016
[2014-06-24 18:07:23] |
salsem - Posts: 43 |
Hello Support SC 1150 AMP/TTNet YM CBOT not update my position on trade all ok for ES CME correct update positions on trade Date Time Of Last Edit: 2014-06-24 18:08:00
[2014-06-24 18:22:28] |
What is the exact symbol of the chart or trade DOM? What is your current position for YM ? What is the position that is shown on the Trade >> Trade Orders and Positions >> Positions tab? If you see a position for the YM on the Positions tab, what is the exact symbol of that position? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-24 18:46:11] |
The Symbol is YM 201409 CBOT Current position is flat Trade >> Order an Positions >> Trade stats for Chart YM 201409 CBOT is -1 I lost today with YM $ -95.00 While in ATW (attach trade window to chart) see a loss YM $- 5.00 |
[2014-06-24 19:40:53] |
We see that TT has changed one of their FIX fields which is causing problems with the position calculations in Sierra Chart from the FIX adapter. We are making changes today to not rely upon the field they have changed, but at this time, no one can rely upon an accurate position display for their account when using TT FIX. For help with the Daily Profit/Loss, refer to: https://www.sierrachart.com/index.php?l=doc/helpdetails81.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-24 19:41:39
