Date/Time: Thu, 28 Nov 2024 10:48:46 +0000
Interactive Brokers Position Reporting
View Count: 429
[2023-05-02 02:56:15] |
fykemang - Posts: 49 |
How do I change the Interactive Brokers account for which I would like to show positions for?
[2023-05-02 16:33:22] |
Refer to the following: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-02 17:21:34] |
I can see my orders but not my positions. I have already tried this. I believe a while back there was a change which removed the ability to show positions for Interactive Brokers except for the first account in the list. How do I change the primary account I would like to show positions for Interactive Brokers integration?
[2023-05-03 14:38:11] |
Sierra_Chart Engineering - Posts: 17201 |
Make sure you are on the current version of Sierra Chart: Software Download: Fast Update The setting you are referring to is Global Settings >> Data/Trade Service Settings >> Main Settings >> Account Index for Subscribe to Positions. After changing this reconnect to the data feed.: File Menu: Procedure to Reconnect to the Data and Trade Servers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-05-03 14:38:47
