Date/Time: Thu, 28 Nov 2024 12:38:41 +0000
Study volume at price threshold v2 and trigger sg1
View Count: 275
[2023-05-01 21:49:51] |
User741988 - Posts: 14 |
Hi, When i display the study volume at price threshold v2 into a spreadsheet I notice that alert count number sg 59 have one more alert than trigger count. Example for a same bar the alert count number is always greater than the number of the trigger. And always it is the first trigger in the bar which isn’t taken account . There is some set up to fix in the input parameter maybe? Thanks for your help All the best |
[2023-05-02 15:35:47] |
We are not able to reproduce this. When we look at the count of alerts it exactly matches the number of boxes that are drawn for the bar. Can you please get us your chart that shows this issue so we can take a look. It may have something to do with your particular settings. Refer to the following for how to post the chartbook: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
