Date/Time: Thu, 28 Nov 2024 12:58:47 +0000
[User Discussion] - Apextraderfunding Rithmic or Tradevoate - Sierracharts Execution, Copy Trading
View Count: 352
[2023-05-01 19:31:04] |
User624595 - Posts: 207 |
What are the differences in using Rithmic vs Tradeovate for Apex Funded Trader accounts, executing through Sierrachart? How can copy trading to multiple accounts function with either of these connections, executing through Sierrachart? For any traders using them, how do they diff in costs/function when trading live accounts for payouts? Date Time Of Last Edit: 2023-05-01 19:43:57
[2023-05-01 21:24:03] |
Apex uses Rithmic for their purposes. We are not aware of any use of Tradeovate, but it does not really matter, as you can not use Sierra Chart with Tradeovate. How can copy trading to multiple accounts function with either of these connections, executing through Sierrachart?
Refer to the following: Order Allocation to Trade Accounts For any traders using them, how do they diff in costs/function when trading live accounts for payouts?
We have set this as a User Discussion for others to comment on this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-02 12:57:07] |
@John - SC Support , Tradeovate connection through Apex uses CQG. Can that CQG connection not be used to execute in Sierrachart? |
[2023-05-02 17:06:19] |
Tradeovate specifically does not allow for the use of Sierra Chart.
