Date/Time: Thu, 28 Nov 2024 11:29:47 +0000
[User Discussion] - Can I detect arrows are pressed with ACSIL
View Count: 245
[2023-05-01 14:15:38] |
Tony - Posts: 522 |
Hi, Is there a way to detect arrows are pressed with ACSIL? Thanks! Date Time Of Last Edit: 2023-05-01 14:16:57
Private File |
[2023-05-01 16:03:44] |
JohnR - User831573 - Posts: 306 |
Tony, ACSIL Interface Members - Variables and Arrays: sc.KeyboardKeyEventCode sc.KeyboardKeyEventCode Type: Read integer variable. The sc.KeyboardKeyEventCode variable is set to the standard Windows virtual key code when there is a keyboard keypress event and the study has requested these events by setting sc.ReceiveKeyboardKeyEvents. Also refer to sc.SupportKeyboardModifierStates and sc.CharacterEventCode. Hope this helps, JohnR |
[2023-05-01 17:17:46] |
Tony - Posts: 522 |
Thanks John! I'm running Sierra with Linux+Wine, for unknown reason sc.ReceiveKeyboardKeyEvents+sc.KeyboardKeyEventCode don't work (no response), although sc.ReceiveCharacterEvents+sc.CharacterEventCode work great. I tested sc.KeyboardKeyEventCode in Windows 10 running under VirtualBox, it works fine, so it must be Linux/Wine issue, couldn't figure out what it is, I guess I will have to live without Key Events. Thanks again! Tony |
