Date/Time: Thu, 28 Nov 2024 12:48:12 +0000
Connection alerts not sounding
View Count: 345
[2023-05-01 13:14:11]
User213504 - Posts: 69
I have alerts set up for connected and disconnected. They are in the Genera/alerts tab but don't sound when Sierra connects or disconnects.
[2023-05-01 17:21:07]
John - SC Support - Posts: 36350
You have specific alerts selected for Global Settings >> General Settings >> Alerts >> Server Connected Alert / Server Connection Lost Alert?
And are those alerts setup for sounds? Refer to the following:
General Settings Window: Sound File (Global Settings >> General Settings >> Alerts)
[2023-05-02 14:42:21]
Yes, see uploaded picture
imageimage_2023-05-02_104056553.png / V - Attached On 2023-05-02 14:41:05 UTC - Size: 44.06 KB - 87 views
[2023-05-02 17:16:39]
You have Alert 1 shown for the specific settings. Make sure Alerts 17 and 18 also have a sound associated with them.
[2023-05-02 17:32:24]
They are. The alerts disappeared when I copied the menu.
[2023-05-02 17:48:04]
On the Alerts page in the General Settings, when you select the "Test Sound" button for Alert 17/18 are you able to hear the sound?
If you can hear the sound when selecting the button, but do not hear the sound when you select "File >> Disconnect" or "File >> Connect to Data Feed", then go through the items here:
General Settings Window: Troubleshooting for Alert Sounds That Do Not Play
[2023-05-02 17:57:52]
Duh!!!! I had muted alert sounds and forgot about it. Thank you. I'm sorry for bothering you.
