Date/Time: Tue, 18 Feb 2025 23:00:47 +0000
conecting label study to price study
View Count: 345
[2023-05-01 10:23:23] |
User278398 - Posts: 291 |
hello, i took "volume point of control for bars" study(from chart#1), and i represent it price with line dash(in it subgraphs) by"study subgrraph above/below bar as text" study in chart #2... i want to get also "label text" which will be next this line dash, how can i do that? regards |
[2023-05-01 17:13:37] |
John - SC Support - Posts: 38033 |
You can not get a "Label" to align next to each dash that makes up a study. The labels are only meant for the last bar in the chart. The one option would be to set the Subgraph Draw Style to Value of Subgraph. This will then give you the actual price at the price lavels. Refer to the following: Chart Studies: Value of Subgraph (ACSIL: DRAWSTYLE_VALUE_OF_SUBGRAPH) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-02 10:20:52] |
i will be specific... i'm using "volume point of control for bars" study(id1,sg1) and by that im getting the price of it (for each candle bar) with "study subgrraph above/below bar as text" study, by line dash(in it subgraphs). also by formula study im getting the result of bdap(id1,sg1) of this poc price, and this result im represent with "study subgrraph above/below bar as text" study, by custom value at y(in it subgraphs). how can i get this value ( bdap(id1,sg1)) ) and connect it to the location of his poc price ? regards |
[2023-05-02 16:58:29] |
What is "bdap" and what exactly do you mean by "connect it to the location of his poc price"? What exactly do you want to display and where do you want to display it?
