Date/Time: Thu, 28 Nov 2024 11:40:54 +0000
Question on diplay of P/L
View Count: 234
[2023-05-01 09:54:18] |
maxm1987 - Posts: 116 |
Dear support, please have a look at the attached screenshot of my P/L window. One point of the NQ shoule be worth 20$, since in this moment I was down roughly 3 points, the PL shows -77,51 -- my assumption is that the window shows the PL only for one contract, but since I traded 6 contracts in this instant, the PL should show 6 times the amount. Can you please advise how to correct that? |
Unbenannt.PNG / V - Attached On 2023-05-01 09:51:29 UTC - Size: 66.92 KB - 73 views |
[2023-05-01 15:04:31] |
Sierra_Chart Engineering - Posts: 17201 |
Refer to the instructions here: Help With Daily Profit/Loss Value: Simplified Steps to Solve Incorrect Daily Profit/Loss Also refer to: Profit/Loss Calculations and Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
