Date/Time: Thu, 28 Nov 2024 11:33:14 +0000
Consolidated tape
View Count: 370
[2023-05-01 05:42:19] |
seandunaway - Posts: 269 |
I'm really excited to start using the new NASDAQ/NYSE consolidate tape tomorrow. Is it ready? Will I need an update? I'm on ARM 2489. Also by any chance do you have a list of exchanges included? Will there be an exchange column available? Thank you for your amazing software! Date Time Of Last Edit: 2023-05-01 05:42:39
[2023-05-01 08:32:31] |
Sierra_Chart Engineering - Posts: 17201 |
Yes an update is definitively required and we will generate a new ARM build today. Regarding the list of exchanges, that is something we do not know but it includes, everywhere each stock is trading. At least within the US , including dark pools. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-05-01 08:33:20
