Date/Time: Thu, 28 Nov 2024 00:25:12 +0000
Sierra Chart is outing of memory
View Count: 390
[2023-05-01 03:16:16]
User101919 - Posts: 27
Hi there,
Something happened to my programs Sierra Chart & Teton: I can not open them as well, the RAM its like out of memory.
I didn't download something else.
I didn't change any settings of the programs.
My computer is getting crazy while the program is running and I don't know what to do.
Picture attached below.
Thank you.
imagescdown.png / V - Attached On 2023-05-01 03:15:18 UTC - Size: 43.28 KB - 99 views
[2023-05-01 03:41:15]
Sierra_Chart Engineering - Posts: 17199
First we think it is related to the issue here which we provided a technical notice for (first technical notice) :
2023-04-11: Technical Notice and New NASDAQ Global Indexes Data Feed! | Post: 344121
There are instructions to resolve this. Go through those instructions.
Also we see you are running an older version. You must update to the current version of Sierra Chart. You are using the Teton order routing service and there are critical updates. Instructions to update:
This will also resolve the problem.
Date Time Of Last Edit: 2023-05-01 03:42:21
[2023-05-01 15:30:21]
Thank you very much Guys. I have only trades tiny windows issue. attachee photo below.
imageT2.png / V - Attached On 2023-05-01 15:30:16 UTC - Size: 21.18 KB - 75 views
