Date/Time: Thu, 28 Nov 2024 11:50:27 +0000
Cannot open files on startup
View Count: 314
[2023-04-30 23:54:11]
User431096 - Posts: 12
In my General Settings->General->Open Files On Startup, there is no ADD button to click. Please refer to the attached screenshot.
imageScreenshot from 2023-04-30 19-41-39.png / V - Attached On 2023-04-30 23:52:58 UTC - Size: 13.9 KB - 87 views
[2023-05-01 02:01:02]
Tony - Posts: 522
In the middle of that window, on the right side of (Button), click on
[Select Files To Open On Startup]
There will be another window pop up and the Add button is in that new window
Date Time Of Last Edit: 2023-05-01 02:01:26
[2023-05-01 02:31:20]
Hi Tony,
I actually clicked on [Select Files To Open On Startup] many times before I asked for help. What happened is that the pop up windown went to the corner of my other screen (I have two screens). And my second screen was kind of cluttered at the time which caused the pop-up window to be obscured.
Many thanks for your help.
Date Time Of Last Edit: 2023-05-01 02:40:10
