Date/Time: Thu, 28 Nov 2024 11:36:33 +0000
Does a hidden study take up resources?
View Count: 311
[2023-04-29 22:27:22]
cuckiecheese - Posts: 63
I imagine a study takes up resources when it has to draw in real time, so am I correct in assuming that if it is hidden then it won't take up any significant amount of resources?
[2023-04-29 23:54:02]
User688525 - Posts: 259
Refer to High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often for optimizing Sierra Chart performance. Under section 30.1, the documentation states: "Even when a study is set to be hidden, it will still be calculated and does not eliminate the calculations. Although it does eliminate the graphics processing if it is on a visible chart."
[2023-05-01 14:18:35]
Sierra_Chart Engineering - Posts: 17201
Yes that is the relevant information. Graphics processing is significant.
