Date/Time: Thu, 28 Nov 2024 09:54:32 +0000
[Locked] - Teton Order Routing Maintenance
View Count: 555
[2023-04-29 19:47:07] |
Sierra_Chart Engineering - Posts: 17201 |
We are doing maintenance for the next several hours on Teton order routing. Failover mode is now going to take effect in a few minutes.
[2023-04-30 00:26:03] |
Finished.
[2023-05-06 11:05:50] |
Teton order routing has been taken down, for about 2 hours for maintenance this morning. 2023-05-06. Work will be done before 8 AM central time. Connections are not possible. The backup system is not allowing connections because we did not want to put the system into failover today. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-06 13:32:20] |
Maintenance is finished. Connections to Teton are now possible.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-05-06 13:32:49
