Date/Time: Thu, 28 Nov 2024 11:25:38 +0000
ACSIL chart color functions
View Count: 636
[2023-04-29 14:15:09]
Marmany - Posts: 307
In the release notes for 2494 it states that:
"The following ACSIL member variables are no longer supported: sc.ChartBackgroundColor, sc.UseGlobalChartColors, sc.ScaleBorderColor. They have been replaced with the following ACSIL functions: sc.GetGraphicsSetting(), sc.SetGraphicsSetting(), sc.SetUseGlobalGraphicsSettings(). These new functions provide a full comprehensive access to all color and graphic settings of the chart. Documentation will be added for these new functions as soon as possible."
I would like to find out how to code the new functions prior to updating but can not locate them in the online documentation.
Please advise.
[2023-04-29 14:56:21]
Sierra_Chart Engineering - Posts: 17201
The documentation for these will be added in about a week but we are putting together an example now. We will post this in a few minutes.
[2023-04-29 15:10:21]
SCSFExport scsf_GraphicsSettingsExample(SCStudyInterfaceRef sc)
  SCSubgraphRef Subgraph_SimpleMA = sc.Subgraph[0];
  // Set configuration variables
  if (sc.SetDefaults)
    // Set defaults
    sc.GraphName = "Chart Graphics Settings Example";
    sc.StudyDescription =
"This example will change the color of the chart background, when the price is above a simple moving average. Add this study during a chart replay for a demonstration.";
    sc.GraphRegion = 0;
    Subgraph_SimpleMA.Name = "Simple Moving Average";
    Subgraph_SimpleMA.DrawStyle = DRAWSTYLE_LINE;
    Subgraph_SimpleMA.PrimaryColor = RGB(0, 255, 0);
    sc.AutoLoop = 0;
    return;
  // Do data processing
  if (sc.IsFullRecalculation)
    //Specify to use the chart graphic settings.
    sc.SetUseGlobalGraphicsSettings(sc.ChartNumber, false);
  uint32_t Color = 0;
  uint32_t LineWidth = 0;
  SubgraphLineStyles LineStyle = LINESTYLE_UNSET;
  for (int BarIndex = sc.UpdateStartIndex; BarIndex < sc.ArraySize; BarIndex++)
    // Simple moving average in the first subgraph
    sc.SimpleMovAvg(sc.Close, Subgraph_SimpleMA, BarIndex, 10);
    sc.GetGraphicsSetting(sc.ChartNumber, n_ACSIL::GRAPHICS_SETTING_CHART_BACKGROUND, Color, LineWidth, LineStyle);
    if (Subgraph_SimpleMA.Data[BarIndex] < sc.Close[BarIndex])
      if (Color != RGB(255, 0, 0))
        Color = RGB(255, 0, 0);
        sc.SetGraphicsSetting(sc.ChartNumber, n_ACSIL::GRAPHICS_SETTING_CHART_BACKGROUND, Color);
    else
      if (Color != RGB(0, 0, 0))
        Color = RGB(0, 0, 0);
Date Time Of Last Edit: 2023-04-29 15:11:00
[2023-04-29 22:46:55]
Tony - Posts: 522
Works great! Thanks so much. The issue mentioned in This Post does not exist any more, same custom study (re-compiled after upgraded to 2497).
Date Time Of Last Edit: 2023-04-30 15:34:17
