Date/Time: Thu, 28 Nov 2024 11:35:18 +0000
Issue with Data Files Folder Not Set....
View Count: 316
[2023-04-28 23:52:42]
User589447 - Posts: 10
WHY am I having this error message. Didnt seem to be an issue until I UPGRADED my account. Maybe I should downgrade???
Thanks in advance
(see attached)
Date Time Of Last Edit: 2023-04-29 00:49:03
imageScreen Shot 04-28-23 at 06.48 PM.PNG / V - Attached On 2023-04-28 23:49:13 UTC - Size: 5.39 KB - 75 views
[2023-04-29 09:26:24]
Sierra_Chart Engineering - Posts: 17201
Refer to:
Important Technical Notice: Very Limited Historical US Stock Data or No Data
You need to update Sierra Chart to the current version:
[2023-04-29 21:28:30]
The update fixed it. Thanks for the quick reply and resolution!
