Date/Time: Tue, 21 Jan 2025 04:02:59 +0000
Custom Studies
View Count: 2108
[2014-06-23 19:18:15]
User55763 - Posts: 4
Hi, I would like to add a new custom study. However, in my Account Info I can see: Not enabled for any third-party provided custom studies. How can I enable new custom study?
Thank you,
Roman Pury
[2014-06-23 19:48:03]
Where does this study come from? Something that you have developed yourself.
Date Time Of Last Edit: 2014-06-23 19:48:15
[2014-06-23 20:00:36]
No, I did not developed it myself. It has been sent to me as a member of a trading course.
/* Relative Volume Study
Copyright (C) Bob Duffy 2013 bobduffytrading@gmail.com
This program is free software; you can redistribute it and/or modify it under
the terms of the GNU Lesser General Public License as published by the Free
Software Foundation; either version 3 of the License, or (at your option) any
later version.
This program is distributed in the hope that it will be useful, but WITHOUT ANY
WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details at
http://www.gnu.org/licenses.
[2014-06-23 20:19:50]
Therefore, follow the instructions here to use it:
http://www.sierrachart.com/index.php?l=doc/doc_DLLUsage.html#ACS
It does not require any authorization by the developer.
[2014-06-24 17:24:35]
I have tried to follow the instructions but unfortunately, it doesn´t work.
My custom study is in .cpp file. I have downloaded the compiler and tried to convert the study to .dll file. As far as I can judge, the compiling process was succesfull:
-- Starting build of Custom Studies Source files: relVolume.cpp. -- 18:59:44
"C:\SierraChart\CPPCompiler\bin\g++.exe" "C:\SierraChart\ACS_Source\relVolume.cpp" -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -o "C:\SierraChart\Data\relVolume.dll"
-- End of Build -- 18:59:45
However, I can´t find the resulting .dll file in C:\SierraChart\Data\relVolume.dll nor can I find the study directly in Custom Studies of Sierra...
Do you have an idea, where could the problem be?
I attach part of the code, is there anything wrong with it?
later version.
#include "sierrachart.h"
SCDLLName("RelVolume4j")
// #define FREE_DLL 0 // Set nonzero to make study reloadable
bool isWeekendDay(const SCDateTime& dateTime);
SCString fmtDateTime(const SCDateTime& dateTime);
SCSFExport scsf_RelativeVolume24j(SCStudyGraphRef sc)
SCSubgraphRef relV = sc.Subgraph[0];
SCSubgraphRef cumV = sc.Subgraph[1];
SCSubgraphRef avgV = sc.Subgraph[2];
...etc
Thank you for advice. Roman Pury
[2014-06-24 17:50:40]
Follow the instructions here:
Resolved: No DLL File Generated with Built-In Sierra Chart Compiler
[2018-07-30 12:07:26]
CTBSD - Posts: 10
I copied the following files into a new computer. Super simple and everything works exactly the same except on error.
ESU18 [CB] 5 Min #6 | Error loading Custom Studies DLL: C:\SierraChart\Data\relVolume_64.dll. Windows error code 126: The specified module could not be found. | 2018-07-30 08:05:10 *
I see the file relVolume.dll in my data folder. Is the _64 the issue?
Data Files Folder
Accounts.config
GlobalSymbolSettings.xml
KeyboardShortcuts.config
ListedTradeOrders.xml
SCStudiesDefSettings.ini
Sierra3.cfg
TradeActivityLog.dat
TradePositionData.xml
[2018-07-30 17:14:45]
The problem would seem to be that particular DLL file has another dependent file which is missing. You need to contact the developer about that. We do not know.
