Date/Time: Thu, 28 Nov 2024 11:42:33 +0000
How do I execute this order?
View Count: 278
[2023-04-28 17:46:04] |
Gravity369 - Posts: 18 |
HI, Please find attached file with a drawing from pen and paper. I want to execute one Attached Order with a Buy and a Sell order and attached LIMIT & STOP orders. I am trying to understand how to do this using TRADE DOM. Does it have to be done programmtically? regards Naga. |
attached order.pdf - Attached On 2023-04-28 17:46:00 UTC - Size: 162.69 KB - 99 views |
[2023-05-01 14:41:07] |
In general, what you want to do is setup through the Trade Window and setting up the Attached Orders. Refer to the information here: Attached Orders You would just need to add 3 targets and 3 stops in your Attached orders. But, you can not define the quantity for each order by percentages. You have to enter the actual quantity value for each one. If doing the quantity by percentages is part of your requirement, then this you would have to do through a custom study. Refer to the following: Automated Trading From an Advanced Custom Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
