Date/Time: Thu, 28 Nov 2024 14:02:05 +0000
# Session times
View Count: 318
[2023-04-28 15:01:08] |
User478380 - Posts: 184 |
Hi I have 2 nq charts and both have different sessions times. How can I set a session time to be used for all charts of that symbol please? Thanks! |
[2023-04-28 15:59:54] |
You can use the linking option between the charts. Refer to the following: Chart Settings: Linking For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-28 16:04:42] |
So you mean to say that there is no global setting that can be used to change session times for a particular symbol and the way to achieve this is to link the charts and then set the session time on one chart which will affect all the other linked charts? Can one link different symbols together ie the es and nq and apply the same session time to both even though they are different symbols ? Thanks! |
[2023-04-28 16:07:14] |
As long as the charts have the same link, any link item applied will apply to the charts, same symbol or no.
[2023-04-28 16:09:41] |
Thanks mate ;-) Issue resolved |
