Date/Time: Thu, 28 Nov 2024 13:41:47 +0000
Verticle Lines on Chart
View Count: 290
[2023-04-28 11:42:16] |
mailo - Posts: 1 |
Hello Team, I want to remove the vertical lines off my chart but i do not know which study is providing them. Any help on what these lines are called or documentation would be helpful. Thank you. https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=80088 Kind regards Mailo |
Attachment Deleted. Screenshot 2023-04-28 at 7.36.39 pm.png / V - Attached On 2023-04-28 11:39:18 UTC - Size: 59.47 KB - 83 views |
[2023-04-28 15:04:46] |
We have no idea where those are coming from. You would have to go through your studies and remove them, one by one, until you find the particular study that is doing this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
