Date/Time: Thu, 28 Nov 2024 09:52:42 +0000
Do drawing alerts not work in replay?
View Count: 452
[2023-04-27 22:53:22]
j4ytr4der_ - Posts: 938
The only drawing I really ever use is a horizontal line. I have a default alert attached to it, which I change to either Above or Equal, or Below or Equal, depending on my needs. This works fine in live markets, but as soon as I go to replay the alerts will never trigger. Nothing appears in the alert log at all.
I thought I had used drawing alerts in replay before but now I'm not sure. Are drawing alerts supposed to work in replay?
[2023-04-28 14:29:28]
John - SC Support - Posts: 36350
It should work during replay. What kind of replay are you running and at what speed?
[2023-04-28 15:38:58]
Accurate system testing, and any speed at all, speed has no impact.
[2023-04-28 16:29:47]
We are not able to reproduce what you are seeing. It works fine for us.
Please get us the chart for which you are having an issue and we will see if we can reproduce it with your chart. Follow these instructions:
[2023-05-07 21:33:58]
I had to move on from this but at some point I will see about sending you a chartbook. Thanks.
