Date/Time: Thu, 28 Nov 2024 13:51:48 +0000
# Empty section in chart due to study
View Count: 262
[2023-04-27 17:42:35] |
User478380 - Posts: 184 |
hi please see attached thanks very much! |
empty section in chart due to study.png / V - Attached On 2023-04-27 17:42:28 UTC - Size: 99.34 KB - 72 views |
[2023-04-27 17:51:09] |
Sierra_Chart Engineering - Posts: 17201 |
You can reduce the height of that Chart Region. Refer to the instructions here: Working With Charts: Chart Window and Regions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-27 17:58:26] |
Thank you. I didnt see the horizontal line on the right. Issue resolved ;-) |
