Date/Time: Thu, 28 Nov 2024 13:45:33 +0000
HSI Symbol translation between CQG and SC data
View Count: 506
[2023-04-27 16:45:53]
chiqsin - Posts: 6
I'm looking specifically at HSI of HKFE.
Looks like there's a problem when translating between CQG's F.US.HSI?## and the SC data HSI?##-HKFE (default SC Data Symbol is HS?##, I switched to a custom symbol of HSI?##-HKFE which is what I find on the Find Symbol list under SC data).
Looking for help here.
[2023-04-27 17:30:27]
Sierra_Chart Engineering - Posts: 17201
Do you mean using the Edit >> Translate Symbol to Current Service command?
Date Time Of Last Edit: 2023-04-27 17:30:35
[2023-04-27 17:49:26]
This is now resolved.
The translation will work.
Date Time Of Last Edit: 2023-04-27 17:49:36
