Date/Time: Thu, 28 Nov 2024 13:59:36 +0000
# Chart outside a window in sierra
View Count: 408
[2023-04-27 11:58:02]
User478380 - Posts: 184
hi
please see attached file
thanks
imagechart outside window.png / V - Attached On 2023-04-27 11:57:54 UTC - Size: 58.25 KB - 82 views
[2023-04-27 13:38:20]
Sierra_Chart Engineering - Posts: 17201
Have a look at this page:
Detaching and Attaching Chart Windows
[2023-04-27 13:43:56]
I think you misunderstood my issue. The chart is attached. The issue is that the price bars in the screenshot I provided are off the screen. Is there a button I can click to get all the candle stick bars to appear within the chart window itself if so are off the screen please?
Thnaks!
[2023-04-27 14:19:29]
File attached
imageprice bars off the chart.png / V - Attached On 2023-04-27 14:19:21 UTC - Size: 46.87 KB - 80 views
[2023-04-27 15:26:14]
John - SC Support - Posts: 36350
Refer to the following to reset scales:
Chart Scale and Scale Adjusting: Resetting the Scale
[2023-04-27 15:28:23]
Thank you so much !
Issue resolved ;-)
