Date/Time: Thu, 28 Nov 2024 13:58:08 +0000
mark intersection between 2 studies?
View Count: 222
[2023-04-27 11:25:13] |
User278398 - Posts: 291 |
hello, i have 2 studies: bid&ask depth bars - which show line of ask and bid&ask depth bars - which show line of bid ... how can i mark/alert/label when there is intersection between them ? (example in the uploaded pic) regards. |
[2023-04-27 15:04:03] |
You would use the "CROSSOVER()" function to do the test. So you would create an alert that looks like the following: =CROSSOVER(ID1.SG1, ID2.SG1) Where ID1 is one of the Depth Bars studies and ID2 is the other one. SG1 is the subgraph you are using for the data. You will have to adjust these for your particular setup. Refer to the information for Alerts at the following link: Study/Chart Alerts And Scanning For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
