Date/Time: Thu, 28 Nov 2024 13:54:07 +0000
there is a study for mark a bar candle ?
View Count: 252
[2023-04-27 11:02:16] |
User278398 - Posts: 291 |
i'm trying to find a study (or other operation) which mark (in any way) a candel which in his close, his body look like in the pic i upload (10 percent body and 90 percent tail) there is somting like that? rgards. |
[2023-04-27 14:59:23] |
Check the "Candlestick Pattern Finder" to see if any of these does what you want: CandleStick Patterns Finder The other option is to use the Color Bar Based on Alert Condition where your alert condition is the bar type you are looking for. Refer to the following: Color Bar Based on Alert Condition For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
