Date/Time: Thu, 28 Nov 2024 13:42:46 +0000
# Ninja trader data box replication in Sierra ?
View Count: 341
[2023-04-27 11:00:07] |
User478380 - Posts: 184 |
Hi, Please see attached file. Thanks |
Ninja Trader data box replication in Sierra.jpg / V - Attached On 2023-04-27 10:59:56 UTC - Size: 196.41 KB - 91 views |
[2023-04-27 12:03:47] |
Sierra_Chart Engineering - Posts: 17201 |
This is done through the Chart Values tool and the Compact Tool Values Window: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-27 18:14:26] |
This issue is resolved Thanks for the support! ;-) |
