Date/Time: Thu, 28 Nov 2024 13:58:18 +0000
# Font size
View Count: 324
[2023-04-27 09:28:59] |
User478380 - Posts: 184 |
hi please see attached. thanks |
font size.png / V - Attached On 2023-04-27 09:28:51 UTC - Size: 54.67 KB - 90 views |
[2023-04-27 10:41:08] |
Sierra_Chart Engineering - Posts: 17201 |
Yes that is the Chart Text Font. It will change other text on the chart as well: Graphics Settings: Fonts and Text Appearance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-27 10:44:50] |
Thank you for clarifying this issue.
