Date/Time: Thu, 28 Nov 2024 14:02:30 +0000
Max Show market order
View Count: 278
[2023-04-27 07:37:40] |
Richie1 - Posts: 5 |
As an example, can a market buy order of 20 contracts be automatically split into 20 1 lot orders? "Max show" So instead of a 1 tick order, it will show on time and sales as 20 ticks? Thank You |
[2023-04-27 14:31:51] |
If you are wanting to see 20 1 lot orders as a single 20 lot order in the Time and Sales then you need to set the Combine Records option to something other than Do Not Combine. When using the Denali Exchange Data Feed, you can set the option Combine Records into Exchange Reported Original Summary Trade. Refer to the following: Time and Sales Window: Combine Records >> Combine Records into Exchange Reported Original Summary Trade For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
