Date/Time: Thu, 28 Nov 2024 13:47:15 +0000
How to get data for those contracts further than what is available on the Available Symbol
View Count: 273
[2023-04-27 02:43:22] |
jowj - Posts: 2 |
Hi, I was hoping to find out if I can get future contracts data for those that are further out in time than what is shown on the Find Symbol function. For instance, SOFR3, I'm looking for the December 2024 contract but I'm unable to figure out how I can extend it further back in time. |
[2023-04-27 14:10:24] |
To get contracts either forward or backward in time, you just need to enter the symbol rather than select it from the list. For example, for the 3-Month SOFR, you would need to enter the December 2024 symbol using whatever format for your trading service, but replacing the contract month with the "Z" for December and "24" (or "4") for the year. Such as SR3M24-CME (again, you have to adjust for your particular service). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
